I have been trying to find more info on this auto shift knob. It look similar to the Levoc gungrip in design (the way it works) so it should fit not sure though has any one tryed this one yet???? I had in mind buying it bacause i'm planning on doing the RS body conversion and thought this "RS Type" auto shift knob would go along with the cars theme of RS. I found this shift knob at it at:
http://www.rsversion.com
It sells for $18 US Dollars
its all metal construction, spring loaded and once installed its easy to shift as simple as push down and select the gear the let go & it locks in. OD switch will need to be relocated...
So if any one has tryed it or is planning to now let me know deal...
if no one does or has then i will post my results when it get it. Its only $18 buck worth a try and no big loss if it doesn't fit or work right. Can alway go back to stock.
[ 12-09-2002, 03:41 PM: Message edited by: Team-Black ]
