1 - 3 of 3 Posts
Freakin\' weirdness w/ side lights...
Okay, so sometimes my side lights don't work. Yesterday evening, they just started going all wonky. First, the passenger side stopped working. Checked some fuses, changed a headlight fuse, and it started working again. Put in nice, new bulbs today, and for a while, the other side wasn't working. All fuses are fine (so they seem).
NOW it seems that my side lights are fine except when the headlights are on. That is, unless I'm using my hazards which work regardless.
I've had e-spec hellas wired up for a while now w/ the front indicators relocated to the little bulbs in the high beam housing. Everything was fine until the above started, now neither of my front indicators work at all.
What the crap,
Rusty
Discussion Starter #2
Re: Freakin\' weirdness w/ side lights...
TTT
Help please! Would LOVE to have this corrected by JetFest...
mayb check ground point..it might be dirty, or loose.
or check all wiring, there might be wire burnt or..connector is loose.
1 - 3 of 3 Posts
