Re: Front Signals Used For DRL\'s????
Yeah, I realised that later on in the day...The switching hot wires wouldnt allow you to see the flashing...But, like you said, hook the bright-side hot into the side marker lights; making sure to use a relay so you dont burn up the wiring...This gets you brights when you have the parking lights on, and they will still flash (however they will no longer alternate with the sides)
...I have sort of figured out how youd need it wired to revert back to normal with the headlights on, youd actually need two relays...One set up for normally-open, and one set for normally-closed...You would actually end up having two circuits for the bright side...One would be the normal circuit, and one would be where it taps in to the side markers...And each would have a relay in it...This should allow the signals to do what you want...I can get more in-depth if youd like me to, in case I confused you here...
