Front Wheel Bearings and ball-joints
2.8K views 67 replies 20 participants last post by  garyk
With the "Search" currently down, I'm forced to post...
My Right Front has started "whirring" in the last couple days. I had a Honda Challenge regular who's a friend of mine ride along to confirm my suspicions. Right Front wheel bearing.
My questions...
How Long can I go while witing for a part?
How much $$$ is the part?
Replace as needed, or in pairs only?
How difficult/What's involved in the job?
Thanks in advance.
Re: Front Wheel Bearings
It's hard to say how long you can wait, probably somewhere between a day and a month....lol. It can fail anytime.
I believe the last time I checked, it was about $50.00 for two, but prices may vary greatly depending on locality.
I like to replace in pairs, if one goes, the other is probably not far behind.
The job is fairly simple if you have a press or a front wheel bearing kit. Otherwise, it's tough with the usual suspects of hand tools.
I found a place to get take-off parts nearby, so I buy the entire upright with bearings and wheel studs for about $100.00 for both. It also gives me great, easy to change, track spares.
$$$ about $100
Labor about 4 hours (you have to separate the bearing from the knukkle, and hub sleeve, be sure to have a cut off wheel (90 degree) and a big press.
Bearings can be purchased separately..don't have the part # handy.
I wouldn't compete if you can hear it...I have replaced mine twice already!
Difficulty rating: 7-8 out of 10 due to tools required and physical labor.
michael, you may remember my post in feb about this. for me it's going to be part of my annual maintenence to replace the bearings AND hubs. when the drivers side broke, we also replaced the passenger side.
Millie's Rocks....
So, given the fact that the labor is still a Seperate Project for each side, you'd still recommend both at once regardless??
ah yes michael. we were there 2 weekends ago. thought of you and the rest of the track whores. btw, came up with a cheap place to stay for g and w. 40 bucks a night with a lake front view. sleeps 3 or 4. 10 minutes from track.
Just make sure you dont have any protruding bolts on your exhause system... I knocked mine of twice going in there.
Ok, here are my findings on this end.
I pulled some of the hubs and bearings from the trash can taken in on cores. Of the ones I looked at (three hubs and three bearings) the hubs are marginal where they were pressed out of the bearing.
However, two of the bearing I looked at have copper colored balls. Only a step below blue balls. (!) and that's HEAT my friend. Lots of it.
I'd really suggest that you attempt to pull the bearing apart and do some high temp grease in there. Mobil 1, Royal Purple, Redline, your choice. I'm betting your problems go away.
I have used the Mobil 1 grease in other applications and have had horrible problems with it seperating. IMHO I would go with one of the other brands.
Could you do it in a stock size? Oh, what the hell I don't even know why I'm asking, I should be in a CRX this time next week.
I have a slight "whirring", as Michael put it, coming from the front right wheel. It is so faint that I can only notice it with the windows down. The best place to detect it is on a quiet country road. It doesn't start until I'm up to speed somewhere around 40mph. And it seemes to be more prevalent when slightly turning in one direction. And it will sometimes go away when I'm turning in the opposite direction. It's only present when under steady state cruising conditions. Like when you're holding the car at say 45. With a light tap of the brakes or a punch of the throttle, it goes away but then comes right back once you return to zero acceleration (positive or negative).
I had the car in for state inspection yesterday at a place that I trust. I told them about the noise and asked them to see if they thought it was the wheel bearings. They said that they could not reproduce the noise and that the wheel bearings seemed OK. What do you guys think? Is it the wheel bearing(s) or just the brakes? The brakes are Mintex A/F on EBC rotors and are only about 1 year old. But I didn't use any of that "anti squeal" grease that came with them.
Just trying to distinguish between a bad wheel bearing and possible brake shoe noise. Michael, could you more clearly describe the "whirring" you heard? Also anyone, is there a way to check the wheel bearings withough taking things apart? I tried to rock the wheel when I had it up in the air to change wheels the other day and everything felt solid? Any other suggestions? Sorry if I sound like a noob. Just trying to learn. And I want to make sure that things are safe before my next track day.
If you can feel it by rocking the wheel, you need to park it.
Mine started out almost like tire noise over a coarse-grained pavement, but only in the right front, and it was obviously wheel-speed dependent. Yes, it's only heard when off the gas, (On our cars...
) but once you start hearing it, it will stick with you even with the radio on at medium volume, because for me anyway, I can FEEL it ever so slightly in addition to the noise.
To further describe it Eric, it sounds like, "WHHHHIRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRR".
It's not Loud yet, but it's pretty obvious for me that mine's not related to the brakes at all, as braking has no effect in the sound, other than reducing the frequency of the Whirring.
To further describe it Eric, it sounds like, "WHHHHIRRRRRRRRRRRRRRRR".
Thanks for the extra info Xi! So, since the wheel bearing "feels" tight (by shaking the wheel/tire), and the whirring stopps when I ever so slightly rest my foot on the brakes, it appears that my "WHHHHIRRRRRRRRRRRRRR" is most likely brake shoe related and not bearing related.
Back to the heat issue. My ball bearings were an beautiful, iradescent purple. How does one flush the original grease out and put in new stuff? Sorry, I have only ever changed sealed bearings!
I'd have to see what they look like first, but on any other car that I've had where I "re-packed" the bearings we just soaked them in parts cleaner(kerosene). Then blew them out with air. Then you put a glob of grease in your palm and hold the bearing in your other hand. You push the bearing into the grease countless times until the grease works itself all the way into the bearings. This sound farmiliar guys?
Or, will things just go all over the place when you take our Focus bearings apart to change the grease? Haven't seen what they look like yet. It would be cool if someone wanted to post a pic.
Edit: I can't believe I posted that 'cause I'm sure Rich knows about this. Just a little confused today I guess. I just can't imagine that Rich has never re-packed wheel bearings before???
