FS Cylinder head \"upgrade\" questions
As the proud ouwner of one of your cyl heads I have a few questions for you as I look into what to do with the car this winter.
1: Does Kent have a hotter cam available than the "fast road" cams that ship with the FS head.
2: Considering the valve springs are cut stock units in your head, can HD units be cut to the same specs and used?
3: Has FS ever messed with using oversized valves in this head? If so, who supplied the valves and did you simply cut them to the same specs as your units valves. If using oversized valves in this head is not a good idea, please explain why.
Thanks Randy
Thanks Randy
