1 - 3 of 3 Posts
After a long time away from the focus world, I recently picked up an 05 zx3. Purchased the fswerks race exhaust and should be installing this weekend, looks straight forward just one question. For those of you who've done this install before, what's the easiest way to remove the dowel pin on the flex pipe flange? Cut it off and file it smooth or take the pipe off and use a hammer and punch to knock it back flush? I don't have a press or air grinder, don't mind using a hacksaw and a file unless it's well worth it to pick up a $15 harbor freight grinder.
Thanks in advance.
Vendor
If you don't have the air grinder or cut off tool then the easiest way is to hacksaw the dowel pin and file it smooth :)
Good luck (y)
1 - 3 of 3 Posts
