Is a 255lph fuel pump too much for a 350whp focus with a turbo setup?
What does the stock duratec pump flow? Does the svt have a returnless fuel system?I am starting duratec turbo build. GT3071RFocusSportVP said:^^^ Right. At 384 WHP we're getting close to the limit I think though. I thought we were done at 350 WHP, but I was able to get a bit more out of it.
harDKore/S2 said:So i've got a 2001, does it have the same pump?
Maybe its the same as the 03 and 04, but from what I know the 2005 and newer pumps are different. I know we've run into some issues on the older Duratecs and fuel pressure. Swapping to the newer 2005 pump cured that, as I guessed it would based on data logs from the 2003 vs. the 2005 during dyno pulls.Hocky said:As has been discussed a million times, the svt pump is the same as the standard 03+ pump.
