Re: Fuel Injector Cleaners
If you must, use a product called Sea Foam. It is a 100% petroleum base product, and will cause absolutely no harm to gaskets, seals, etc. Just follow the instructions carefully. I believe it is 1/3 in the gas, 1/3 in the crankcase (yes, I know, but it will help everything in there ramin clean), and 1/3 thru a vacuum hose (brake booster line to manifold).
It WILL clean all the carbon deposits (thanks unleaded fuel) from the upper end of the engine!
