can you use a higher octane' the manuel says 87 octane is that the only one to use.
B britfolk · Registered Joined Sep 20, 2002 · 107 Posts Discussion Starter • #1 • Oct 8, 2002 can you use a higher octane' the manuel says 87 octane is that the only one to use.
S Shiva Chaos · Registered Joined Oct 4, 2001 · 1,535 Posts #2 • Oct 8, 2002 Only if you have altered your timing with a chip. Using anything other than 87 can hurt your car.
B britfolk · Registered Joined Sep 20, 2002 · 107 Posts Discussion Starter • #3 • Oct 8, 2002 thanks dude.
