I know its behind the fuse box but where exactly, I have a hard time finding it. I'm using a mirror and all I see is a bunch of wire harnesses. Also is it a regular fuse or something diffrent?
just get on your knees outside of your car and look through the little door with a flashlight. it's on the bottom row, really easy to find.
Unless your about a foot tall it will be very hard to see the fuse. When you pull the fuse panel cover off there are two screws, back those out. There are two plastic clips around the same area, push those towards each other. the fuse panel will come out turn it over and you'll see the fuse.
Hope this helped.
After you replace the fuse let me know if the new fuse pops.
I'm having trouble with that. Thanks
Discussion Starter #4
LOL are you really serious?
It's a lot less work if you just kneel next to the car.
