1 - 5 of 5 Posts
does anyone make an aftermarket one?
Discussion Starter #2
ttt
any suggestions on how to seal it off?
Give pacesetter a call.
PaceSetter Performance Products
2841 W. Clarendon Ave.
Phoenix, AZ 85017
Phone: (602) 266-1964
Fax: (602) 650-1136
Hours: 8am-4:30pm MST M-F
Customer Support: [email protected]
They have the Header colletor gasket for merly 7 bucks to go between the header and Cat.
I had to order a new one since I got pissed when doing an install and ripped it off the cat, because of a bolt striping and breaking off in the cat.. luckily I got the bolt out and replaced everything..
Go down to your local parts house and get some high temp gasket material with the metal sandwiched and make your own. That's what I've been doing and it works great. You can use a small ball peen hammer to tap it against the opening to make the outline before cutting. It cut's fine with a sissors and you can use a hole punch for the bolt holes.
[ 01-25-2003, 12:18 PM: Message edited by: dan-d ]
1 - 5 of 5 Posts
