Gauge cluster lights change the color??
15K views 38 replies 10 participants last post by  WuNgUn
Is it possible to go from the green lights to a different color in the gauge cluster and oil gauges?
Do it yourself...
The 'indiglo' lights up white...
The overlay is painted green on the backside.
It's layered over the silver and the digits, so removing it would remove everything.
Scan the overlay, Photoshop the silver out of it, print it on quality white paper and you have your new overlay...and it'll be WHITE.
I did this, and added a blue film underneath and made this...
(Also white and a transparency over the white)
And in the daylight...
(If you look closely, I also Photoshopped out the MPH, enlarged the SVT logo, and thickened the redline)
I don't have any pic's of the current white output though.
More images...
(here is what happens when you try to remove the green from behind!)
I don't use clear anymore...I printed the image straight to paper, add the colour film underneath and your done...
Do whatever you want with Photoshop...I removed the MPH and tweaked the logo redline size.
I didn't like 'reading' the blue face...white looks much nicer, and is way easier on the eyes.
Never thought about using photo paper...it probably doesn't have the transparency to pass the light thru light regular paper...
I just use heavy weight inkjet/laserjet paper...
Here is the original scan...
Here is what I did to it...
Don't use these images...they are compressed, resized, etc...
If you do your own, scan at high res, and work with it as a tiff format, uncompressed, to preserve image quality. And you WILL notice the quality of the print if you compress it (jpeg).
My original, modified image is about 24 MB!
Haha...good question. I used soft-cover binder I found at Office Depot that had a transparent blue cover! It was a tad thick, but worked...
That was the best solution I could find at the time...
Hey wungun. I got the pieces separated and am going to attempt this. But what did you do to the odometer to have it light blue like that? And you just printed the overlay to white paper and cut out the blue for underneath?
Thanks wungun. :)
i notced that after taking the silver stuff off that the lense still had the numbers and stuff on it, but the mph numbers were gone. im confused as to how that happened? i see you edited them out of the photoshopped version but how are they gone from the lense? also if i wanted the guages to light up white then could i just take silver stuff off and just stick a blank white piece of paper back there? or do i have to print the cluster onto it first?
i havent done the mod yet but i do plan to thats why i was asking. i want to better understand the whole process before thearing into it. how can i get the silver stuff off? once its off will the nmbers still be on the lense like yours? if so then can I just put a solid piece of paper back there with nothing printed on it and the light just shine white?
The colours on the gauge face are basically painted on from the back side...looking at the back, you see green, then silver under that then the numbers...So if you go sanding, your gonna end up with uneven are broken thru colour issues...
I tired this with mine first as well...it's ruined.
