1 - 5 of 5 Posts
How does one manipulate the tensioner of the timing belt to get this silly thing off? HELP!!!! FocusHacks wasn't much help foir an SVT. Thanks!
Driver > Car
off completely or off to install a cam gear?
cam gear:
using a 10mm wrench loosen the tensioner. then there are two pins, front and rear. use a pick tool to loosen the tensioner even more with the front clip.
warning, it's FUN to put back on.
completely off:
remove serpentine belt cover (two 10mm bolts)
15mm wrench for the tensioner
remove serpentine belt. remove crank pulley. remove two 10mm or 8mm (i forget) bolts holding the cover. this will expose the timing belt.
remove cam gear cover, loosen tensioner, remove belt. it's fun. (not really)
ok, what exactly is the front clip on the tensioner?
Yes pleas elaborate on the re-install if you could Mook is the one helping me with this little adventure.
Any instructions on how to get your cams lined back up properly? (stock cam gears). Thanks!
1 - 5 of 5 Posts
