Good News about Spec Series
1.6K views 60 replies 16 participants last post by  Ted7rns
It looks like Ford Racing is going to be in the mix at some level (maybe even full time). Along with Ford Racing it looks like TechSport, Leo Capaldi Racing and Gillis Motorsports teams are also very interested in being part of the development and growth of the series. This along with F2 Focus and NASA will be a good foundation to start this series.
I’ll revise what we have going on with the series, and what we’re testing now.
#1 All model Focus will be used from 2000-2005+. No SOHC Focus will be allowed. Yes, this includes the SVT Focus. Weight and Air management will be used to even the cars out, and yes both NASA, Ford and F2 feels it can be done.
#2 We’re looking at two suspension sets ups. The Multimatic Dynamic Suspension inverted struts/shock Kit will be one kit.. the other will be a KW Strut/Shock kit with Spec Eibach Spring. Right now we’re leaning towards the Dynamic kit. All cars can use OEM Rear sway bars or F2 Focus rear sway bars. Front sway bars will remain stock. Ford racing has had a lot of good results with this Dynamic Kit in the FR500 Grand Am Program. It is the same design.
#3 We’re looking at using F2’s SCT ECU Flash units for each Focus. The SVT will not be flashed. The 2.3 Duratech will not have much gain, but the Zetecs will. The ECU Flash unit will remain with NASA
#4 We’re looking at three tires, the Toyo RA1, Kumho V700 victorracer, and the Hankook Ventus RSS Z211. Again, we’re leaning towards the Toyo’s. We also might leave it open to those three tires. You can use any wheel up to 17 x 7.
#5 SVT Focus brake kit (4 wheel) can be used. These kits will be available at a very good price for all Spec Teams.
#6 Torsen T2 LSD is the only LSD we’re going to list to being used now. We will open this up.
#7 Weight and air intake will be used to even out all the models. NASA, Ford Racing, and F2 feels the series should be open to all models. Which makes the most since.
#8 Grearing can be changed to 3.82:1 or 4.06:1.
#9 Only ford wings and spoilers maybe be used… no aftermarket wings or splitters
This is pretty much it for right now….. Please don’t start building your spec car with these rules, there’s a good chance changes might be made.
We are well on are way into this series, test cars are being built right now, and will be on the track in a Month for testing. With all the great support NASA has right now, I’m sure this will take off. I receive emails everyday about more people wanted to build cars. So Cal seems to be the hot bed right now, and looks like SoCal could have 10+ Spec cars by this time next year.
Any questions, please feel free to email me at ted@nasa-tt.com
updated 6/25/05
1)stay away from kuhmo's..great stick but constant supply problems...that's why we dumped them for toyo 2)so now i am quaifed out? this is not particularly good news...
the obvious answer would be to "seal" the ECU somehow. perhaps submit the car's ECU to the vendor and they will put some sort of seal on it after they apply the appropriate program??
Since it will be hard to check everyones LSD. It will remain open. Ford just want to use the Torsen. But it is best that it remains open.
The SCT Flash units will remain with NASA. I believe it will be very difficult to reflash an ECU that doesn't have the OEM info in it. Cars will be checked after each race.
The series shouldnt limit the use of the Limited Slip Differential. Other than that, this looks promising
FWIW, the Quaife warranty is bulletproof (including racing), whereas the Torsen...is not so great. They work exactly the same - why not allow both? I know FR sells the Torsen, but unless they're willing to warranty it, it doesn't seem quite fair.
My only other concern would be the flashing.. what is preventing somebody from buying an SCT package and re-flashing their computer to however they want?
Couldn't you scan the ECU immediately after a race? Just impound the points-scoring cars until they can all be scanned, then release them.
I'm sure it will be open to all LSD. But FYI the Torsen and Quaife are not the same. The Torsen is better for road racing then the Quaife. All three of the Top Focus Touring Car teams use the Torsen.
But since it will be tough check for the LSD. it will remain open.
also it would be nice to see ford racing take into account those of us who spent their own money, time and sweat to build a focus race car.....that should count for something...
It will count, but the most important part is to have a level playing field.
Fair enough, and better overall.
The Torsen and Quaife are virtually the same design, and function on the exact same principle. As for which one's 'better for road racing,' that's a long discussion that isn't necessarily proven by who uses what and who doesn't.
Moot point, however.
agreed..add weight...or handicap..in some of our enduros we have handicapped starts...track record for your class, not your car in particular, is the basis. same thong could be done for previously modified car..see how much weight handicap has to be added based on testing.
For the benchmarking, I assume you'll be using one "Spec Driver"? Don't compare times between different drivers and different cars. Even better, have a number of drivers compare a number of cars. That will give the best results.
Yes, The same driver and the same tires will be testing both cars.
Any chance that you could test *multiple* drivers in the same cars? A single driver could skew the results too much in particular directions, but different drivers with different abilities & backgrounds will give you a much better representation of what works best overall.
^ As always, said with support & respect...we all want SF to be great
I don't know if we'll have time to do multiple tests. But, it will be fair, because I will be doing the first two test. I have no reason to skew the results too much in particular directions.
After we do these time test. Then we'll have multiple drivers race these test cars. We also might be doing a Endro race with one of them in December with Multiple drivers.
Once we get it close. then will be able to set the rules, and play with weight to even them out. I expect that all of 2006 will be that way.
There is no perfect way to do this (Unless you have a tone of money), and I believe this is the only spec series in NASA, to do any pre-season testing at all.
There is a chance to do some more testing in Jan. but that would only be for fine adjustments for weight.
Even if we do try to even these cars out, I expect some models to do better at different tracks.
Oh no, that's not what I'm suggesting. It's more that different drivers perform differently with different changes / parts / etc. Simple example: You might be faster with a 25mm sway bar, but for me - I might be faster with a 22, and find a 25 undrivable... That's all I was getting at.
Perfect.
There is no perfect way to do this <snip> Even if we do try to even these cars out, I expect some models to do better at different tracks.
Of course not. The pre-rule testing is a great start, for sure.
I understand that, but these first couple test or more power tests to even out the models. The handling part will be more fixed. There will be no difference in suspension between the models. So, driving style won't make a lot of difference in these power tests.
I'm glad you're making these suggestions. It always good to get ideas from an experience race car driver like yourself.
Thanks for your support.
I didn't necessarily mean suspension, as differerent drivers can deal differently with gearing and powerband, but...yeah, we're on the same page.
Well, 'experienced race car driver' would be overstating things by a ton, but nevertheless - I'm glad you're open to conversation. Rawk on.
