1 - 13 of 13 Posts
Re: Good spot to run wires and such out to the engine compartmen
The spot I use is under the drivers side fender liner. The main harnesses run through to a main connector behind the fender liner. Next to those, to the left, is a space about 3-4" wide and about 5" tall. PLENTY of space to drill and grommet for a bunch of wire runs.
eric, go to home depot and get some electric grommets and a sealer. smear some sealer around the hole you drill, then pop in the grommet. that way you won't have to worry about the hole you drilled rusting out or slicing your wiring and or vacuum line.
I actually drilled above the clutch pedal...hit dead on perfect and came out under the fuse box. I probably couldnt do it again if I tried..
na = naturally aspirated which means no power adders nitrous, blower turbo nothin
i ran my through the rubber seal around my steering column. It works great.
1 - 13 of 13 Posts
