1 - 3 of 3 Posts
First, got a JSRC, running stock pulley, got th following mods:
65MM TB, 70MM Maf/Stock injectors, JBA shorty, FC HF Cat, Full Bosal w/Flex, FR stage 1 Cams, Findanza Cam Gears, Superchip, FC UDPs, Volant intake.
1) Reburring the Super chip to remove timing
2) Removing the UDP's
What else need to be done, prior to install? What else do you all suggest. Please give me th low down prior to install
i belive you want to find out from jr if the cam is ok to run... i know its 1st. stg. but i think it is better to check 1st. ive seen that you want a cam with a grind on it for sc... on the install, have someone else there to help with the little stuff
The cam is fine install and enjoy...
1 - 3 of 3 Posts
