Can someone that's either bought the kit or gotten a copy of the directions post a list of what all they suggest you connect together? I saw that the official kit comes with 5 wires (in varying length). I've already got materials for installing my car stereo and as part of that I was planning on replacing the battery to ground wire to match the hot wire that I'm running back to the amp (probably a little overkill since part of the reason to run large wire to the amp is to reduce voltage loss due to the long wire and the battery to ground wire is only a foot or two compared to 10-15 feet to get from the battery to amp). I'm not opposed to buying a few more connectors (and a bit more wire if I don't have enough extra) and replacing some more. I know there's one (or maybe two) block to chassis grounds. Still, that's less than the 5 wires that the kit is coming with. Is there a battery to block as well? That'd make sense to upgrade as well... Still leaves me 2 wires short.
Edit: Found a pic of the Mistu Evo install directions. Obviously there are a few differences between it an the Focus, but it's better than blindly installing them. It brings up a couple ov questions, though.
1. Why daisy-chain the ground wires?
2. Why run a special ground wire to the tranny?
3. Why ground a plastic intake manifold? (ok, that was a joke... I know the Evo has a metal or alumnium one)
Ugh, that won't work... I'll re-host it and fix the URL shortly.
