Hey, I'm not really a "rookie"(been here for quite some time actually), used to be FocusZX3Rules, but had a problem so I now have a new name. Anyway, I received my H&R Cup Kit in the mail about 2 weeks ago
, but I can't have it installed for a month(+) because of money issues. So... now that I have time to sit and plan / think, I want to make sure EVERYTHING is done correct and at once. Main concern...camber(or whatever it is on the Focus, but you know what I mean). I just cannot afford to ruin my ES100 tires quickly. How likely is it that a normal alignment done by a good shop will fix the camber issues? My current Progress springs were able to be back to stock, but this new drop is decently lower. How likely is it that camber bolts, or whatever, will be needed? Also, what is the issue with the bumpstops on the front and back when installing the Cup Kit? Is this a concern like it is with the Sportline springs. I was thinking no, because of how stiff the Cup Kit springs are, but it was worth making sure. Are the stock ones ok how they are? Or would trimming them / buying SVT ones be worth the small hassle?
---Also, I have read around about the annoying "ticking"/"chattering" of the front suspension over real little, quick inperfections in the road. I have this, and it's getting even worse. I know it always happens when you lower your car. I heard that it is a pretty simple fix, but what is really involved and what parts are needed? Someone said that Ford wants big bucks(as usual) to fix the problem, so I was planning on having my performance shop fix this while installing the Cup Kit and whatever else(camber bolts[?]) that I might need. Thanks in advance for replies.
--Dan.
--Dan.
