Is it normal for the shifter to be clunky and hard when the temp is below freezing? It gets a little better when driving but not great. Anything I can do to improve shifts? Could my fluid be low or is there anywhere to grease? thanks
sleeperlove said:probably not unless you want to change between winter and summer. tranny fluid is a pretty heavy weight. you could go lighter but would def need to change for the summer.
pitch i think the tapping the gas thing works because it should be helping the shafts in there speed up to the road speed. i think
If your not a salesman you should be!tenderloin said:This companies products rock.
http://specialtyformulations.com/
I live in Southern California and MTL-P is perfect for me. Very smooth with a firm/crisp feel. It does not even seem like the same tranny. No BS
SynchroGlide has a lower viscosity, so it shifts a tad easier in cooler weather. SynchroGlide shifts superbly...smooth as melted butter and a very positive/crisp feel. SynchroGlide is closest to new Ford fluid in feel (ease), but MUCH smoother and more crisp. Night and day IMO.
Again, I personally prefer the slightly more firm/positive/crisp feel of MTL-P. MTL-P is also super smoooooth...They sure use slick stuff
BTW Specialty Formulations makes a product, MTFGLIDE, with the viscosity close to Mercon V, the lowest viscosity of their MTL line. I haven't used it but I imagine it shifts veerrryyyy easily/smooth even in super cold weather..
I have also used Torco MTF and it IMO better than the stock Ford product.
Email Specialty Formulations for their recommendations..it maybe different then mine. NO reason to have balky cold weather shifting.\
BTW these guys stand behind their products 100%
Some info I have put together over time....
Mercon V
cSt @ 100ÂşC 7.5
Specialty Formulations MTFGlide
Viscosity @ 100C 7.5 cSt
Viscosity@40: 39
Specialty Formulations SynchroGlide
Viscosity @ 100 9.5 cSt
Viscosity@40C: 42
Specialty Formulations MTL-P
Viscosity @ 100 C 11.5 cSt
Viscosity@40C: 82
Specialty Formulations MTL-R
Viscosity @ 100 C 14.7 cSt
Viscosity@40 C: 93
Redline MTL
Viscosity @ 100 10.6
Viscosity@40 C:56.2
Redline MTL-90
Viscosity @ 100 15.6
Viscosity@40 C:90.0
Redline ATF
Viscosity @ 100 7.5
Viscosity@40 C:34.0
Redline ATF High Temp
Viscosity @ 100 10.0
Viscosity@40 C:53.9
Torco MTF
Viscosity @ 100 8.35
Viscosity@40 C 53
Torco RTF
Viscosity @ 100 14.3
Viscosity@40 C 82.5
GM/Chrysler Synchromesh
Viscosity @ 100 9.08
Viscosity@40 C 41.6
Royal Purple Synchromax®
Viscosity cSt @ 100°C 7.7
Viscosity@40 C 35.3
The product is great for south cail, but how good is it in the cold ?
