Has anyone put Kumho's on their SVT?
907 Views 27 Replies 17 Participants Last post by  garyk
Has anyone put Kumho\'s on their SVT?
...and if so, how do you like them? Do you feel any differences between those and the stock Conti's? Any response to this question would be greatly apprecated.
1 - 20 of 28 Posts
Re: Has anyone put Kumho\'s on their SVT?
I put exsta mx's on mine and I like them alot more than the conti's, but from what I hear the azeni's might be the way to go.
Azenis aren't made in our size, and I don't think they would grip a whole heck of alot better than the MX's.
SlickShoes
Gandalf
JaySD
and Myself
all run the MX's for street tires. All of us have run the MX's on the track as well, and their compound holds up surpriseling well to excessive beating! We're big fans of the tire, and really believe there probably is no grippier tire for the price.
10
Love em. Still on my first set, but will definitely be getting another one. But this time I'll be going with the 40 series version.
I previously did a whole big write up on them, but it seems to have been lost with the forum upgrades. The gist of it was the 215/45-17's are HUGE. Much taller than the same size Conti's. Definitely go with the 215/40-17's unless you want the increased sidewall height.
Some old pics of the 215/45's...
Check out the beef!
And after probably 30 autoX runs, 7k street miles and 4 track days.
Notice no real chunking!!!
I'm now at 30k miles and probably am hoping to still get another 5k out of them.
These suckers seem to grip very well, yet last decently assuming you rotate once in a while and run proper alignments (in my case almost -3* up front since I'm..ummm... a little agressive with the corners
As for comparing to the Azenis. Seems like the Azenis heat up a bit faster, which is good for short autoX runs, but not for track use. Still, many people (not me) that have run both seems to say that the MX's are just as grippy, and even better in the wet. Also the Azenis don't seem to last nearly as long, but I believe they are asymetric, so you can flip them around if needed which is nice.
Good point. For the money and the right sizes, these are about as good as they get for an agressive street tire. Now, if money was no object or you could find an awesome deal, the Goodyear KD's or the Bridgestone S03's are probably even better (gripper, longer lasting, quieter) though. And for longer lasting but less grippy, you might also look at the Yoko AVS's as people seem to really be liking those as well.
What kind of PSI you run at the track?
2
Yo Slick...you might want to get those puppies changed before it rains
30k on a set of tire the way you drive, I think you got your moneys worth
When I ran the MX's, I had to run really high pressures to keep the sidewalls from rolling too much. I believe it was about 48 front and 42 rear hot.
It was a toss up between running optimal tire pressure for tire wear, or to reduce the chance of rolling the tire too much. As you can see from that picture, it was a little too high for tire wear purposes. But I choose to go with the safer method, use the shoe polish and go a little higher. Especially after seeing, first hand, what can happen if the tire sidewall rolls a little too much and the rim decides to bite into the asphault. I want the shiny side to stay up.
How is the straight-line traction w/ the Kumhos??
Would you say that the sidewall on the MXs are stiffer than the Contis...after about 7 AutoXs at 45psi and up I'm gonna cord the tires where the tread rolls to the side wall...and I only have 10K on the car...I just want a stiffer sidewalled tire when I have to change them out.
CCC
So Slick you were saying the do well in the wet? The conti's don't do all that well in the wet. And up there in the rain capital of the US I could use a little more grip in the wet.
CCC,
Some times it's better to think out of the box.
May I suggest that @ 45+ on the front and they still roll over mite be a case of to fast for the turn.
The conti's are a good w/+, all around tire.Great wet grip,but mostly an OEM product.
Bottom line is imo slow up and use what you got to their max.
Keep in mind that solwer is often faster.
I'm thinking of getting a set of these in the spring. I've heard nothing but good comments on them. Anything negative to point out about them?
BTW - What was the max pressure on the stock Contis?
Umm... I'd guess its probably slightly better due to the softer rubber and larger tread blocks... meaning more sticky rubber on the road. But unfortunately I have no real data on straight line numbers.
I feel your pain. I was in the same boat. Just tearing the crap out of the outside shoulders. Yes, the MX's do seem to have a stiffer sidewall. I have the 45 series tires which as I said, are REALLY tall, and even though with the Conti's I ran pretty high pressures too, the MX's didn't seem to have as much roll at similar pressures. I autoX'd my Conti's for a while and I feel the MX's were definitely a welcome improvement, but don't expect a night and day difference. The stock Conti's are actually pretty damn sticky as is.
Though I think the thing that really has saved my tires is that I went with some front camber plates. No one believes me that by adding an additional negative degree of front camber (currently running -2.5* on each side) has really increased my tire life. Not sure if this is just because I am pretty agressive with the corners, but probably no more so than any of us. And most of my miles are highway miles, so common sense seems to say I should be wearing out the inside quite a bit more. But, my tire wear is pratically text book perfect. I did also change from the stock 1/8" toe in up front to zero toe though. That's probably helping a bit too.
No, what I meant was that I heard they are better in the wet than the Azenis. No idea about the Conti vs MX's in the wet. If we're lucky, it rains here in San Diego more than 5-7 days a year. So I'm the last person you'd want to talk to about wet weather tires.
Hmm... bad things. They probably won't last as long as most other tires. Belacyrf burned through his pretty damn quick, yet mine are still around. Not sure if that's because he had the 40 series and I had the 45's or what. Who knows.. Also, I believe they are slightly louder than the Conti's, but if so its barely. NOTHING like my race tires which literally sound like mud boggers. And considering they are classed as a "summer tire", I'm guessing getting them near snow would be a death wish.
Otherwise, they're just great tires that won't be destroyed by autoX or track days yet are very competitive in street tire classes, are very reasonably priced and they are offered in our stock sizes.
I believe the max pressures of the Conti's are 51 psi. Same as the MX's.
I also have an LSD, which seems to like to aid in tearing the tires up
I have the MX's on my car now. They replaced the Azenis that I had before. Having said that...
The Azenis had a quicker turn-in response than the Kumhos. Other than that, I would give the performance a dead heat, except that I haven't put any rain miles on the Kumhos yet.
Also, the Kumhos are WAY quieter than the Azenis were on the freeway at speed. Overall, either tire is a great choice. But if you plan on leaving the tire on your car, I would go with the Kumho.
(I should say, I do not have an SVT)
Thanks for clarifying, because they don't make an Azeni in our stock size. To bad though... great tire.
Cant disagree with that comment at all...
I'm another satisfied MX user. Now that I have the Mustang, I don't drive the SVTF as much as I used to, but they are much better than the Contis. The Contis were great for a smooth, quiet ride, but they had very soft sidewalls. I have about 5k on my MX's now, including one track day and I like them so much I'm going to put them on my Mustang when the brake/susp. upgrade is done.
I am heavily considering the MX's when I replace my conti's. Right now I have 20k on the conti's and they probably have about 4-5k left on them, however, they are off for my snows (which on a side note work well in the mud). I was also looking at the Goodyear Eagle F1 GS-D3's. They are $9/tire more than the MX's but they seem to get really rave reviews as well. I guess I have plenty of time to look into it though.
1 - 20 of 28 Posts
