1 - 8 of 8 Posts
I have some money to play with, I was thinking of getting my tranny out of the way,torson,LWF,4.06's,CM 4 or 3. After that I was thinking of doing a head I was thinking a FRPP head with FRPP cams Stage 2 or 3 I realy only want to rev past 7500 max(Is that safe on a stock bottom end?). would the 3's do that fine with the springs in that head? would I cut the power range short. how streetable? Are they and how much would I have to mill the head to up the compresion to 10.6-1 with those cams? What kind of power numbers would I be putting down with my current mods and after getting the cams and chip tuned?
Not Special Enough
stay with the stage 2. wilder than that isnt really streetable. Idle will be lousy, even after a tune.
Isnt the FR head 11:1?
power? who knows. dyno will tell you.
the F.R head only will bump up compression w/it being milled, if you want a high redline then go w/ the crower 2's, cat 2's, ect....if you are looking for something w/more of a midrange go w/the FR 2's, cat 1's, crower 1's ect...w/a fully done head w/nice cams, a good tune, all the bolt ons, you should see 160 whp easy w/135-145 lbs of tq.
I have some old crower twos In my room guess I'll use those So the FRPP stage 3's arnt streetable?
Discussion Starter #7
wow thats cool do you happen to have the dyno Id like to se that curve
1 - 8 of 8 Posts
