1 - 3 of 5 Posts
distance
· Registered
Discussion starter · #1 ·
Is this the same problem that Ford had on there Contours/mystique's and later extended the waranty to fix this problem. My fan only blows on 4th speed and was squealing since I got it. Dealer said that it was nothing to worry about, when it was squealing as it was caused by COLD weather. I said "NO" He said "YES". I said "NO" he said..... anyways, it only works on 4th speed (high speed). Does it have to be replaced or is it just a resistor or both? It also seizes once and a while and would stop and start when I first turned it on. Any help would be appreciated. Thanks!
Discussion starter · #3 ·
Would you know if this is covered under the Base Care waranty, as I bought the car with up to 150000kms. I also have no Air on speed 4 which is the only speed that works with my blower!!!!!
1 - 3 of 5 Posts
