1 - 4 of 4 Posts
the sticker on the passenger door was unreadable ,how would I do a search i pulled off the side panel on passenger side there was white sticker around some wires with HMD and MST-14401 on there with some other #'s below that there looked like there was 2 screws under the glove box are those the one i have to undo to get to the chip, if those dont sound like the right codes let me know how to do the search without taking out the glove box....thanks
I believe it's a 4 letter/number code and I never removed the box but kinda wiggled it from the bracket that covers it after undoing one screw. Then the chip slides right in. Fine sand the contacts gently without removing the copper contacts to get the coating off. The box has a big harness plugged into it I believe. As far as the codes go, try asking 1turbofocus(Tom). I'm sure he'll know.
1 - 4 of 4 Posts
