Help! Just Finished Head Install (You\'ll never guess what the problem was)
2nd O2 sensor (blue one) got messed up somethin awful so it's not in there, but everything else is back on and I started it up the first time and it made a loud BANG (sounded like a backfire) then went on to idle roughly, kinda chugging along. After a short idle time, I would hear a clack every few seconds. Anyone know what might be wrong?!?!
[edit]How I fixed it:
I pulled the passenger side motor mount, valve cover and timing belt cover off. When I pulled the valve cover off, I took a look at the end of the cams, to see how far off they were and noticed that the grooves on the cams (where the alignment tool fits in) were no longer parallel to each other. I thought it was kinda strange, but went on removing things. While I was loosening the tensioner pulley I noticed the A on the exhaust cam gear was partially covered by one of the bolts. I didn't remember it like that when they were off the car, so I looked closer. All five bolts were maxed out in one direction and the exhaust cam was set to retard timing 15 degrees!!!
Turns out the 5 bolts weren't tightened out of the box (I know, I feel completely idiotic for not checking this BEFORE), so when I started the car up, the outer sprocket moved, but the cam didn't and the bolts slammed into their farthest points (hence the one loud BANG).
So, I set the cam back to the neutral mark, bolted it all back up and it runs and idles. It's a bit loud with the 2nd o2 sensor out, but I should have my new one tomorrow, and then I'll be all set!!
Thanks so much for all the help guys! I appreciate it![/edit]
[ 02-04-2003, 08:52 PM: Message edited by: SuperMatt ]
