I had an Autocross on Sunday, and the tech guys failed my harness setup. I've got a 4-point harness (soon to be upgraded to 5-point Rob!) that's mounted to the stock lower rear seat belt mounting points. The harness is at about a 45-degree angle from the horizontal, while the CNAC rules require a maximum 40-degree angle.
This has accelerated my desire/need to make a harness mounting bar that sits behind the rear seat. Here's my criteria:
- Obviously, I'd like the bar to be strong enough to hold in a crash situation.
I can do all the calculations for the strength once I determine a basic design.
- Main bar removable in less than 15 minutes. I don't drive on the street with the harness, and I still want to use my hatchback to haul stuff and or people!
- No or very little cutting of interior trim. My wife has to approve, ultimately! It is OUR car.
So far, I was going to use a steel tube (size to be determined) that would span the gap and have the harness mounting points on it. This tube would fit into brackets bolted to the seat mounting points. The mounting brackets would be a steel plate with a welded-on C-shaped piece (tubing cut lengthwise) with an inside diameter a little bigger than the outside diameter of the harness bar. The open part of the C would face the rear of the car. This bracket would overlap 2-3 inches along the harness bar, with bolts holding it in place. With the bar removed, the brackets would stick into the hatch area just behind the rear seats a few inches, but at least it doesn't block off the entire area.
How does this sound? Is my design clear? If not, I can do a little sketch and put it up here.
Is there an easier solution that I'm missing? Thanks!
Twilight Blue ZX3, Koni dampers, Eibach Springs and Swaybars
"Being hit by a meteorite is an accident - everything else is a driver's fault!"
