It's a bitch to get out but, there are two very small clips on ether side of the metal tube part (you can see light through them). Find something sharp that you can stick in between the light ring and the metal where the clips are. I used a knife but a small screw driver should work just as well. Gently pry the plastic away from the metal while applying pressure to the back of the socket. Once you think you've got one side do the other, but keep pressure on it so it doesn't slip back. It just takes allot of patience and is defiantly the hardest thing to get out of the center console.
