So I just had my key ignition cylinder replaced (roughly a week ago). My car a few days ago started acting up. The gas light and rpm won't go on right away when I start the car, it takes a few seconds then they work as normal. My Cd player won't turn on unless I hit the on button and then it says 1hr.
Sometimes my car will also make a grinding noise like its trying to restart. But it only happen when I'm at low speeds when I press in the clutch. All the lights will flicker and then when I release the clutch the car will act like normal. It doesn't happen when I'm at higher speeds and I can shift smoothly in any gear.
Could it be my battery? There is some build up on it and could keep it from getting a great connection. I'm just baffled at what it may be. Its really embarrassing because its such a loud noise. Of course all this happens when I start school up again. HELP!!
Thanks!!
Adam
Thanks!!
Adam
