Well I've finally got all my parts in and am starting to assemble my new motor. Here are a list of parts:
FR Head
FR Intake Manifold
Cat Stage 2 Cams
Cat Stage 2 Springs/Retainers
10.2:1 Compression forged pistons
Eagle H-Beam forged rods
Cam Gears
ARP head studs, main studs, rod bolts
Custom burn chip
70mm Mass Air
32lb injectors
65mm TB
This will be my first build, though I'm doing this project with my father who has tons of experience with older cars.
Here's where I am right now:
We clayed a piston today with the head on the block with no head gasket and it's hitting big time - obviously I'm going to have to do some work with the bucket clearances...
After talking with our machine shop guy, we decided that the easiest thing to do to get the clearance we need would be to shave the needed distance off the top of the valve stems. I know some guys with this head are getting custome buckets machined, and some are digging around in drums of buckets finding the right size but I haven't heard anyone mention doing it this way. I can't think of any reason for it not to work. The intake side we found to need about an additional .018 and the exhaust side needs a good .022 We're thinking about taking .025 off each valve stem. Between that and the addition of the head gasket we'll have a good clearance.....
What do ya'll think?
Anything ya'll can do to help would be GREATLY appreciated.
FR Head
FR Intake Manifold
Cat Stage 2 Cams
Cam Gears
Custom burn chip
70mm Mass Air
32lb injectors
65mm TB
