Hi
I just bought a new HID, today I installed it and it turned it out did not work. I just wondering how do they connect as I found out the connector from HID only has 2 jacks to put into factory connector, while the factory connect has 3 jaks to connect. I need your help guys if u know how to install....please tell me...
Thank
the connectors are as follows:
Pin 4: Ground
Pin 6: High Beam
Pin 7: Low Beam
for HID, you only need ground and low beams.
What do u mean by Pin? Can u explain more...what i did is i connected HID to the factory connector, but because the factory connector need 3 jacks to plug it in....and the HID only have 2 jacks .....any ideas?
The plug that goes into the headlight has 3 pins, basically, just unplug the connector and match the pin number that I posted above, with the colour of the wire. One thing though.. I highly don't recommend HID upgrade kits that re-use your stock headlight lens. They create too much glaire for oncoming drivers.
