Where would the best place to install a cat on the 2.3 pzev?
Do you think the high flow flex cat would fit from like CFM??
The best place for it would probably be where the second cat is. A high-flow cat should fit fine, as long as you get it with the proper size, but you may need an exhaust shop to weld a flange on so it bolts to the flex.
Thats what i was thinking to just buy that and drop it off at the shop. the flex cat is what ill probably do. ill keep u posted....
In California, IIRC, you can replace your catalytic converter if it was damaged beyond repair (and not "oh no! someone bashed my cat in with a tire iron in the parking lot of this performance shop!" damage). It must be replaced with a certain type of aftermarket cat, which don't flow as well as high-flows.
Edit: Those of us in the wondrous flyover states can replace cats with anything we feel like. Some states will even allow straight-pipes, as long as your car passes hydrocarbon testing.
I love Alabama... Mine is straight off the stock flex right now, but soon it will be straight all the way down...
