1 - 9 of 9 Posts
Hey I dont know if anyone has talked about this or maybe even had the same prob. but, when I am almost to a stop my car rev.s up, not a lot but still... I have Mac intake, underdrive pullies, Pro M mass air. Help me!
Yeah I have the same prob the rpms hang up there around 3-4k for like 5 seconds after I have already stopped.
Also my gas milage suckes only getting 180 miles to the tank.
[ 03-06-2003, 09:40 PM: Message edited by: D ]
No delete button?
[ 03-06-2003, 09:55 PM: Message edited by: cRaZySHO88 ]
Sounds like an MAF to TPS problem. Still got the flow sheet for your MAF?
Its sure sounds like the TPS. Have you washed the Engine recently? Or have you "played" with the TPS. Yes! Try unplugging the TPS Sensor found on the throttle body. If you then drive your focus you will have some lights on the dash but see if it stops the problem. I believe motorcraft part is $20 in SA its R550. You wil notice that performance is up but she then drinks gas
Discussion Starter · #7 ·
Thanks guys. It's not real bad but it's just one of thoughs things that gets to ya after a while.
Crazy-... not sure on the flow sheet, I'll look.
KZN- I will try that tonight.
mabey you should try asking rod and see if he will fix it for you > lol
1 - 9 of 9 Posts
