1 - 12 of 12 Posts
i'm guessing they are needed w/o disturbing some cosmic force. can i shave them off to lighten the flywheel?
Removal would diabale the car. For a simulation, unplug the crank angle sensor located at the transmission end of the block, under the exhaust manifold.
ok...i just realized i'm screwed. a local machinist shaved them off a stock piece i got out of a junk yard, in preporation to replacing the clutch. so now, is there anyway to fix it w/o buying another one?
I would also suggest taking the remains of the flywheel and applying it to various parts of the machinist at high velocities.
Discussion Starter #8
just GREEAATTT!!! ok..so anyone using westside performance in houston, they have no clue what the countersinks are for either
Perhaps you should tell them that they have turned your flywheel into a paperweight and they will help bring in another one. New from Ford, I think they are about $100, so I doubt a used one is going to drop them into Chapter 11.
Well, it might be salvageable, but I doubt it's worth the trouble. You could do what the aluminum flywheel manufacturers do, and bolt a steel ring to the flywheel to act as the "trigger" for the hall effect sensor (the crank position sensor).
But I doubt that would be worth the trouble. Plus it might not even work right with the stock flywheel, since with an aluminum one the trigger wheel is the ONLY metal that the sensor will "see". That is, the stock flywheel might interfere with a simple trigger wheel.
Oh, and what countersinks were you referring to?
.....have a custom made ally holder for the sensor to move it closer to the flywheel holes so it can pick up the signal again from the thinned flywheel...not rocket science!
1 - 12 of 12 Posts
