1 - 16 of 16 Posts
I want to shorten it by cutting it but the rubber cap is tough to remove. How do you do it?
Hmmm..chainsaw???? plasma cutter???
how bout try sliping something in between the rubber cap and fiberglass mast to break the bond, and then pull the thing off
Discussion Starter #6
I tried to heat it with lighter, didn't help.
I will try the boiling water method, thanks.
hehe lighter might melt it. try boiling once it hot enough take some pliers or something and try to pull it out.
Discussion Starter #8
I did it with the boiling water, but god, it was PITA! I bruised my thumb in the process. Putting the cap back on was tough too but not as tough. I just wished I'd apply some grease to it to let it slip.
boil it for like 5 minutes then wrap a towel around it for a grip....you gotta do it when its real warm and it should slide right off............... i remember doing this mod at 3 am cuzi saw it online and just had to try it right then and there...... and i love it
hehe u shoulda just dropped the cap back into the boiling water, it softens it up. hehe
I didnt even think of boiling mine when I cut my antenna. I rolled elctrical tape around the tip to look like a cap. Then torched it a bit, rolling the tape edge at a 45 to round it over. Looks stock.
1 - 16 of 16 Posts
