i took the easy route, i used an adapter off of a 351 motor in place of the stock ( idoit light ) sender. it comes out with a 45 deg. bend that worked out perfectly then a 1/2 adapter for an autometer sending unit, the stock sensor harness not being pluged in dosent throw a mil.... you would think it would. pressure is where it should be i havent had the reported problem of peging out the gauge, so this setup will work if anyone was thinking of doing it.
