1 - 17 of 17 Posts
I'm bringing my car into the school's shop to install my exahust tommorrow, and am looking for a general idea of how long it will take to get the stock one off, and the new one installed, assuming we have air tools and a lift to use?
You will have to cut the factory exhaust off. With a lift and air tolls shouldn't take any more that 30 minutes. An hour at the ABSOLUTE most.
Right on the pinch weld.
the most timeconsuming part of an exhaust job is cutting off the stock system... if you have a torch, you can be done w/ the job in 30 mins easily (not including time to put the car on and off the lift)..
what exhaust did you go with?
if you look under your car where the black molding goes down you will see what looks like 2 peices of sheet metal are welded together, the whole lentgh of the car, just imagine a t. look in your owners manual for jacking point it will show you exactly where
Buy new gaskets, buy new gaskets - exhaust weaks suck! Especially on something like a Bosal. BTW you can usually rent an exhaust cutter from Pep Boys, they suck, but work if thats the only thing you've got.
Discussion Starter · #13 ·
good point about the gaskets. I guess i get to go get a new one this weekend, then install it next week. better than an exhaust leak.
Driver > Car
where it meets the flexpipe, yeah. i reused mine and dont have a leak, but it's cheap enough where it's worth it to save the risk.
i'd say 20-45 minutes to replace the exhaust.
Those exhaust gaskets are metal, there is NO need for replacement! I have had my exhaust on and off my car probably 15 times still have the original ones. I did however break a stud but I just heated it up and knocked it out and put in a bolt.
If your going to replace the gaskets, don't use the same Ford ones. They are thin metal (copper??) and never die, but they don't do the best job of sealing for aftermarket pipes. I spent $10 on this crazy 5 layered gasket and its awesome!! Maybe alittle overboard, but atleast I know I won't get a leak there. Anywho, go to Pep Boys and ask them if you can go in the back and dig around in there exhaust flange gaskets and find your treasure.
1 - 17 of 17 Posts
