1 - 5 of 5 Posts
well u can go buy a window crank tool..or you can do it the cheap way...just be careful...
get 2 flat head screwdrivers...gently push one inbetween the handle and the plastic piece against the door....
this will allow you to see inbetween the 2...look closely and u will see a thin shiney metal clip...try and push it apart with the other screwdriver...
that should do it
or u can take a wash cloth, and pull it between the spacer on the door and pull it up. it works i did it on mine
Get a small, needle point like, cheap screwdriver, and bent the tip up about 1/4" up sp it like this \| Then you can push in the door panel and use your new tool to pull the retainer ring up.
1 - 5 of 5 Posts
