I don't like the front suspension in the SE. It feels loose. When I crawl over a speed bump, for example, the front still takes a big dive but the rear is really tight and does not dive.
If I want to keep the stock springs, then what kind of dampers should I use?
OR
If I change the springs, are there any that don't lower the car?
If I change the springs, are there any that lower the car a little bit?
If I change both the dampers and springs (see above) then what combo?
Thanks.
OR
Thanks.
