yeah they changed the number on the wire leads too, there is now an "e" at the end.
How much were the plugs?
The "plugs", NOT the "headlight socket", that came with the headlights.What do you mean by "what is wrong with the plugs that came with the headlights?" ?
Yeah, I understand what your saying here, but I am not talking about the "VW Style" plug on the back of the headlight housing. I am referring to the "Euro headlight plugs" that came with the headlights.But what is "wrong" with the headlight plugs is they have European "VW Style" plugs on the back. The harness that came with the headlights will only plug into Euro headlight plugs, which you need to get from a VW dealer.
The Xenons come with the extra harness. It's more than an extension harness, it is what you use to run back to the real LCA sensor so the self leveling headlight function works. But if you don't want to install the rear LCA sensor (I didn't) then the harness is not at all needed. The Dynabeam extension harness plugs into the AFS box, so it is needed.The "plugs", NOT the "headlight socket", that came with the headlights.
The picture above shows the same plugs VW would give me, so why am I buying another set of "VW Style" plugs, if I already have a set? I can just cut these and wire them up like you have in the OP.
Your reply makes it seem like I just randomly posted in this thread about wiring the Hella's without actually giving me the benefit of the doubt that I actually know what the hell I am talking about.
I apologize for not having a more specific question, so I hope the picture helps with what I'm saying about using the plugs that came with the headlights.
The plugs that do not have the black goo sealing them up, cut it off and wire it into your car's wiring harness. You will have extra wires that you won't use though, don't worry about them.The "plugs", NOT the "headlight socket", that came with the headlights.
I had absolutely no idea what you were asking, so I took my best shot at answering it :dunno:Your reply makes it seem like I just randomly posted in this thread about wiring the Hella's without actually giving me the benefit of the doubt that I actually know what the hell I am talking about.
It's more than an extension harness, it is what you use to run back to the real LCA sensor so the self leveling headlight function works. But if you don't want to install the rear LCA sensor (I didn't) then the harness is not at all needed.The Xenons come with the extra harness. It is just an extension harness.
I was not aware the extension harnesses included in the Xenon kit were for the LCA sensor. Thanks for clearing that up.It's more than an extension harness, it is what you use to run back to the real LCA sensor so the self leveling headlight function works. But if you don't want to install the rear LCA sensor (I didn't) then the harness is not at all needed.![]()
Just an FYI the part number for the vw plugs has been updated to 6R0-973-735 although giving them the old part number wasn't a problem when I went.
Hey SVT3658, can you possibly update the original post to reflect updated part numbers so folks don't get confused? Newb's like me get confused easily! :lol:yeah they changed the number on the wire leads too, there is now an "e" at the end.
Has this been verified? If so, can we update the original post with this info too for the same reasons as stated above? I just purchased the Dynabeams and won't be able to install them until August but when that time comes I won't have much time to redo everything if I do it wrong the first time.For the Hella Dynabeams the Ground in pin 8 (for turn signals/parking lights) of the VW connector needs to go into pin 7.
You have saved me. I want to go to HIDs on my ST170 but the whole switching thing is the only reason i havent. THANK YOU THANK YOUYou would be completely correct :thumbup:
