1 - 2 of 2 Posts
Alrite, so what would cause only my back tires to be bald at 22,000 miles? I havent done any burn outs, donuts or brake torques...At around 12,000 miles I installed Eibach Sportlines. It seems like after the springs were put on, the rear tires' tread wore out extremely fast.
Now, the front tires are almost perfect.
And just this morning my drivers side rear tire went flat.
The steal beltss were showing on the outside part of the tire... Theres finger sized hole in the inside of tire, so i know why it went flat.
But why are just my rear tires bald????
Monday i'm getting 2 new stock 15's...will an alignment solve any camber problems???
Sorry for the long post, but i had to explain.
sounds to me like an excessive wear angle... camber or toe... most likely camber since you lowered the car... take it in for an alignment and see. 45 bucks for that is cheaper than tires...
1 - 2 of 2 Posts
