does anyone get hum from their udp? its a focussport udp
P p_townZX3 · Registered Joined Aug 21, 2003 · 763 Posts Discussion Starter • #1 • Aug 21, 2003 does anyone get hum from their udp? its a focussport udp
B BUR_ZX3 · Registered Joined Apr 24, 2002 · 19,264 Posts #2 • Aug 21, 2003 you sure its not your air conditioning? no hum except when running air conditioning here!
P p_townZX3 · Registered Joined Aug 21, 2003 · 763 Posts Discussion Starter • #3 • Aug 21, 2003 it hums at normal idle. Sometimes it goes away but then comes back.
T TooleBox · Registered Joined Oct 15, 2001 · 1,649 Posts #4 • Aug 21, 2003 did you shave down the lip on the dust cover? it may be your belt rubbing... I dont quite know what you mean by humming. Is it a vibrating sorta hum? or a rubbing sorta hum?
icemanZX3 · Registered Joined Dec 26, 2000 · 5,620 Posts #5 • Aug 21, 2003 I have the Esslinger and it damn near sounds like a turbo in 1st and 2nd gear.... normal I think.
