1 - 18 of 18 Posts
First thing I noticed is that the car drives much smoother and NO STUMBLE
I used some roofing copper that I found at a jobsite. there's two bolts that hold it inplace to a pipe that runs to the intake, un-did it took the gasget and shapped the copper to it, and put it back togetter..
Marco
[ 02-19-2003, 06:43 PM: Message edited by: Low Focus ]
Driver > Car
still connected to your exhaust?
any more power???
What exactly do you need to do to remove. I know you have to remove the tube from the exhaust, the EGR itself and plug the holes on the exhaust and intake, but what about the DPFE (however its called) and small little vac. tubes???
Thx!!!
well other then the egr being pluged in to the intake and exhaust manifolds it there is i think 2 support bolts that have to be taken off and then you need to take the sensor off from were it is and leave it pluged up...just lay it in the engine bay or zip tie it to something. Also the little hose thats attatched to the silver disk looking thing just take a screw and plug it up and thats it. You will be supprised how much room it frees up.
Discussion Starter #8
I left the sensor hooked up I just blocked Off the egr to the pipe thats go's the the intake..
No cell
Marco
No cell
Marco
<font size="2" face="Verdana, Arial">Thats what I did. And when it comes time for emissions, it still looks as though its hooked up.
I didnt do it to remove the stumble, I have a turbo, and it was bleeding off boost through the tiny holes on the bottom (not anymore baby!)
L8r
BJ
Driver > Car
So it still is connected to the exhaust part, just blocked on the intake side?
what are the benefits of this?
Discussion Starter #12
I did this cause I was sick of the stumble at 2000rpm Now thats fixed I'm happier than a kid at Christmas. The car just drives better.
<font size="2" face="Verdana, Arial">So it still is connected to the exhaust part, just blocked on the intake side?
Do you see the copper.
Marco
[ 02-19-2003, 06:46 PM: Message edited by: Low Focus ]
Car Czar of Death
i plan on making a complete EGR removal Kit.
consisting of:
1 22mm bolt for heh header end.
1 aluminum plate with gasket for the intake manifold end.
3 little rubber caps to block off the 2 dpfe sensor ports, and the one EGR sensor port on the firewall.
let me know what you think
Chris
[ 02-20-2003, 08:26 AM: Message edited by: CTZX3 ]
consisting of:
Chris
<font size="2" face="Verdana, Arial">I'd hit it.
Originally posted by Pimp27:
I would purchase something like that. I'm lazy and its too much work to go search for the right parts yourself.
Eric
<font size="2" face="Verdana, Arial">meeee tooo, sounds like a good idea, work us up a pri....eeeerrr PM I mean...hehe
Discussion Starter #18
by blocking the egr the car runs and drives better, this system is the weak link to this car.
I have no cell, and I love it.
1 - 18 of 18 Posts
