Ford Focus 2000-2001
Alarm and Keyless Entry Wiring Colors and Notes
Constant +12 Volts: RED IGNITION SWITCH HARNESS
Starter Kill: GRAY/BLACK IGNITION SWITCH HARNESS *
Ignition +12 Volts: GREEN/YELLOW IGNITION SWTICH HARNESS
Power Lock: BLACK/RED (-) DRIVER'S KICK IN DOOR BOOT ***
Power Unlock: BLACK/YELLOW (-) DRIVER'S KICK IN DOOR BOOT *** Trunk Release: BLACK/YELLOW (-) AT TRUNK RELEASE SWITCH
*** See Installation Note - Negative Pulse Door Lock Diagram.
Remote Starter Wiring Colors and Notes
Start: GRAY/BLACK IGNITION SWITCH HARNESS *
Ignition #1: GREEN/YELLOW IGNITION SWTICH HARNESS
Brake Light: GREEN/RED (+) AT SWITCH ABOVE PEDAL **
Tach Signal: BLACK/LT. GREEN AT COIL MODULE
Parking Lights: ORANGE/YELLOW (+) AT LIGHT SWITCH
* This Vehicle Is Equipped With Ford's Passive Anti-Theft System.
. ** This Wire Is Only Active When The Ignition Is On.
AUDIO NOTES:
radio constant 12v-- ORANGE/BLACK (thick)
radio ground--- BLK/YELLOW &BLK/GREEN
dimmer +12v---- ORANGE/BLACK(thin)
Lfront +white/blk -gray/blk
rfront +white/red - grey/red
Lrear + white/purple - grey/white
Rrear +white - grey
**also behind radio is the speed sense wire which is :: white/green
(handy for remote starts!**)
The keyless module is located behind the glove box to the right
There is where you can find a factory hood pin black/yellow
power windows are as follows:
LF windows up/dn---> yellow (drivers door motor), white
RF window up/dn-----> yellow/purple (driver switch or kick panel),
white/purple
LR window up/dn------> yellow/blue(driver switch or kick panel),
white/blue
RR window up/dn-------> yellow(driver switch or kick panel),white
