I just wanted to share the IAC removal I had today and the stuff to maybe make it quiker and easier for anyone attempting in the future...
1. Jack car up at least a foot on jackstands or higher w/ lift
2. Lay with your feet out towards the drivers side of car (under the axle area)
3. Use a 1/4 in. drive ratchet with a short 8mm socket, manuever around a little and it will work. The long socket was good to break the torque but not to tighten.
4. When pulling out the valve slide it straight over to the drivers side (through the manifold)to an opening which can be reached from the top of the engine area (if on jackstands) where you can easily disconnect the wires and remove the valve up and out. (this is all to the drivers side of the tps plug/sensor)
Note: while you have the valve off you can put a blower or vacuum up to the IAC channel under the t/b to push and pull any debri left behind in there as well.
5. The harness on the Valve will always face the drivers side of the car.
6. Putting the valve back in is the same way as it came out. And the screws will be easily started and tightened w/ fingers most of the way too..Use the 1/4 In. rachet and small 8mm socket to tighten the final 1/4 to 1/2. If you cant tighten down the screw with your fingers the rachet will give you enough room to work. Tighten only to 10-20 in. lbs as the nutplates are plastic i believe, and i didnt want to take the chance stripping the manifold out.
I am sorry if this is more than required for typing, I just wanted to have some "searchable" reference for the future IAC problem people like me....
Robert
Robert
