Re: Idle help
How long has it been doing it?
I would guess it's the idle air control valve first and the tps second.
Damn.air leak around the TB gasket. get some carb cleaner and spray it around the base of the TB. do it slowly so if the engine revvs real hard, you know where the leak is. you may also have damaged the TPS. I've heard of it happening before though Im not sure how.![]()
