1 - 4 of 4 Posts
Lets say I wanted to make my idle hang more. How would i go about that? Right now they drop and bounce then die. I the blow off piped back in. I also have an SVT, but that should not have any difference on the steps on what to change to get them to hang more.
Thanks
Ok for idle, all i did was change the RPM to 1000. But I tried a few things in dashpot. I left it stock, then i tried someones(maybe Welding Rods) Idle settings. But coming from lower RPMS it seems to stall more than when Im higher in the RPMS and let off the gas.
I can get you the actual settings tonight.
Did somebody say "dashpot"?
dashpot write-up
That link shows what I did to allow the revs to drop quickly while keeping the engine stall-proof. With a blower, your dashpot needs may be very different, but my data might give you some ideas for what changes to try.
1 - 4 of 4 Posts
