1 - 4 of 4 Posts
Important Alternator Inst Q - Else I can\'t get to work tomorrow!
Quickie, I've just installed a new Alt in place of my failed one (73k '00 with some ICE) the only issue is, there's a connector to the alt which seems to be a sensor pigtail of some sort, of which the wires have pulled out of the harness. The question is: what order do the wires go back in? I'm stuck without a diagram or service manual.
Any help would be appreciated, even if you happen to look under the hood, I think it should be grey, red, blue top to bottom but not totally sure. or if anyone can crack open a hynes that would rock also.
Re: Important Alternator Inst Q - Else I can\'t get to work tomor
From the CD-ROM manual it looks like this is how it goes:
Looking down the connector end...
__-__
<u>|1 2 3|</u>
1) GY (Green/Yellow?)
2) BU (Blue?)
3) RD (Red?)
Not Special Enough
gy is grey.
Discussion Starter #4
you most certainly are a lifesaver.
the info is correct for anyone who may need to use it.
thanks so much for taking the time to look!
1 - 4 of 4 Posts
