Not really tricky. The chip plugs into the box under you glovebox and the code should be on your passenger door. Other than that do a search.
i installed mine in less than an hour. in the zx2's, you have to take the center console out so i would think it would be less time for foci. make sure you clean those contacts well.
Discussion Starter · #4 ·
the sticker on the passenger door was unreadable ,how would I do a search i pulled off the side panel on passenger side there was white sticker around some wires with HMD and MST-14401 on there with some other #'s below that there looked like there was 2 screws under the glove box are those the one i have to undo to get to the chip, if those dont sound like the right codes let me know how to do the search without taking out the glove box....thanks
Discussion Starter · #5 ·
If the sticker came off the door, I am pretty sure that you will need to get to the pcm and get the code from the sticker on it.
