Pull the panel out, and check voltage with a multimeter. black i think is ground, and one of the wires is hooked to the dimmer switch. To check this, check voltage v. ground and dim the switch, it should drop voltage.
Easy to do. I hooked my interior neons to this, so i can dim them.
