1 - 12 of 12 Posts
GReddy doesn't make a wiring harness for the focus so I have to hard-wire in the unit. It should be pretty easy to do, but I just need to know which wires on the ignition harness I need to splice into for the turbo timer. if anyone has any ideas please help, thanks!
pm tekin112 he has one in his car
I've installed on in a mazda miata.
It's not very hard to do at all. Use T-taps, or solder the connections.
Needed are 12v, 12v switched, ground, ignition, rpm, that's it I believe. The instructions have detailed instructions about the color of the wire.
Don't short out the ignition wire. This will blow the relay, and leave you stranded. at least this happened to my friend.
Discussion Starter · #4 ·
apparently he doesn't have one.
I already know what voltage wires I need to find, I was just hoping someone would have done this before so I wouldn't have to bust out the voltmeter. Oh well, guess I'll get to work now.
or maybe he didnt want to help
it was but he still had a timer in it at one time
Hey i got the same turbo timer and im gettin ready to install it as well... hey once you install this if you could make some directions and pm me with them or post them that be great help...
thanks
jason
Discussion Starter · #10 ·
If anyone knows where the 12V constant, power ON, and Accesory power lines are on the ignition harness that's all I need to know, thanks!
12V - red
Ignition - green/yellow
Accessory - yellow
make sure you meter the wires first, there's more than one yellow under there, and dont be afraid to let the wires loose from the little trsy they sit in, it makes it easier. If you need any other wiring help pm me.
1 - 12 of 12 Posts
