This may seem like a stupid ? but I need to know. Are the intake manifolds from the SVT the same as the regular 2.0zetec motor?
No.. The SVT intake is a plastic Dual Stage Intake (DSI) The runners swing around inside to lengthen or shorten at a given RPM.
I think the bolt pattern is different some as well.
Not sure the bolt pattern is different, it might be, but the ports are definately differently . The intake runners from a 2.0 zetec (non svt) will not line up with an SVT head.
I just talked to a guy from cfm and he said the turbo kit he had would work with some piping changes I assumed just piping not the manifold. Cause it says nothing about it being SVT compatible.
If your talking to CFM than your talking about the Precision Turbo Kit. Yes you'd have to change the intake piping as well as the down pipe! That is ALOT of work.
